Web Content Viewer
Actions
Web Content Viewer
Actions
Get Your Complimentary Test Reports
TEST YOUR PARTS FREE >
Download Brochure and White Papers
BROCHURE > WHITE PAPERS >
Get Technical Information and Quote
CONTACT US >
Sign Up for Newsletter
CONTACT US >
Web Content Viewer
Actions
3D MACHINE VISION FOR RANDOM BIN PICKING
3D random bin picking is a challenging area in manufacturing industries that has perplexed engineers for years.
To meet this challenge, Canon has aimed for and created a solution that utilizes Canon's leading optical and processing technologies. The installation is simple, yet the system is sophisticated. It automatically recognizes parts, determines the best pick candidate, and calculates the most optimal path so that the robot can safely, but surely, pick up the part and move it to its desired destination. It is a complete solution for random bin picking on any production floor.
Random Bin Picking in Mass Production
Canon’s advanced 3D Machine Vision guides a robot to pick and place resin molded printer parts which are randomly piled in mass production line.
Overhead view of random bin picking
Illustration of random bin picking. Click image to enlarge.
Web Content Viewer
Actions
SIMPLE FLOW OF AUTOMATION
Incorporating the Machine Vision system into your production line is easy. Setup is simple with the use of user-friendly software. Simply dump the parts into a bin and hit the start button. The system will search for the best pick candidate from the pile based on your application. Your robot, fully integrated with Canon's Machine Vision system, then automatically picks the part and places it, getting you ready for the next process with ease.
1 SETUP
BIN
Screenshot of software with sample pallet info
PART
Screenshot of software with sample part info
HAND
Screenshot of software with sample hand settings info
GRASP
Screenshot of software with grasp data
2 3D Scan
Quick Process
3D machine vision system over bin of eyehook bolts
3 RECOGNIZE
Precise CAD Fitting
CAD view of eyehook bolts
4 PICK
Sophisticated path planning and collision check algorithms
Machine arm reaching into bin
5 PLACE
No additional scan needed due to precise recognition
Machine arm placing eyehook bolt on table
Web Content Viewer
Actions
PROVEN RECORDS IN MASS PRODUCTION
Car door panel
LARGE
Car Door Panel
1.4x1.7m/4.6x5.6ft
Tubes open and close
PARTS THAT CHANGE SHAPE
Metal plates with holes
GLOSSY
Metal Plate
Use HDR* for easy recognition of glossy parts
Lid with holes
THIN
Lid
3mm/0.12in
Use "Recognize as Thin Work” capable of 4mm/0.16in or less (RV300)
Long hexagon bolt
LONG
Hexagon Bolt
320mm x Φ 16mm
Cable clamp
SMALL
Cable Clamp
24mm/0.9in Width
Minimum size 10x10mm/0.39x0.39in (RV300)
*HDR is High Dynamic Range
Web Content Viewer
Actions
OPTIONAL SOFTWARE
Batch Recognition By Multi-Pallets Option
Using a single captured image, this option enables position and orientation recognition of work pieces piled in multiple pallets.
Consecutive Recognition Checking Option
This option enables consecutive recognition upon confirming that the pile state remains unchanged after each work piece has been picked.
Dictionary Creation Option
This option enables the creation of dictionaries, required for the recognition of new work pieces, on a PC other than the PC connected to the 3-D Machine Vision Head.
Partial Work Recognition Option
Using partial CAD data, this option enables recognition of parts even for large work pieces that extend beyond the measurement range.
Slider Option
This option enables measurements from multiple locations by moving a slider-equipped 3-D Machine Vision Head.
Web Content Viewer
Actions
SPECIFICATIONS
RV Series
RV300
RV500
RV1100
RV1100+ Option
Measurement area
H x W x D
340 x 340 x 100 mm
(13.4” x 13.4” x 3.9”)
540 x 540 x 200 mm
(21.3” x 21.3” x 7.9”)
1160 x 1160 x 600 mm
(45.7” x 45.7” x 23.6”)
See the red framed trapezoid area.
Minimum recognizable part size
10 × 10 mm
(0.39” x 0.39”)
20 × 20 mm
(0.79” x 0.79”)
45 × 45 mm
(1.77” x 1.77”)
50 × 50 mm
(1.97” x 1.97”)
Recognition time *
1.8 sec 1.8 sec 2.5 sec 2.5 sec
Dimension of 3D Machine Vision Head
252 x 206 x 129 mm (9.9” x 8.1” x 4.9”)
Weight of 3D Machine Vision Head
6.5 kg (14.3 lb)
IP Rating
Equivalent to IP54
Operating Temperature
0 – 45°C (32 – 113°F)
* The time is measured by using an eyebolt M30 for RV1100, an eyebolt M12 for RV500 and an eyebolt M8 for RV300 as a target work, and setting the default measurement modes and the default recognition parameters. (Measurement period may vary depending on target work, measurement modes and recognition parameters.)
Web Content Viewer
Actions
SYSTEM CONFIGURATION
For the PC: Windows 7, 8.1, or 10 Professional, along with an nVidia GeForce graphics card and Intel Gigabit network LAN card, is required. Please contact Canon for the most up-to-date PC requirements.
Flow chart of the Canon 3D Machine Vision system
Diagram of Canon 3D Machine Vision System. Click image to enlarge.
MEASUREMENT AREA
Diagram of Measurement Area
Diagram of Measurement Area. Click image to enlarge.
Web Content Viewer
Actions
Boost Your Manufacturing to The Next Level
Learn about the possibilities for your bin picking applications with our 3D Machine Vision System
FPE Automation Tech Expo logo
October 15, 2019
10am – 3pm (CDT)
Arlington Heights, Illinois
www.fpeautomation.com/techexpo
Come and See Canon’s 3D Machine Vision Technology Yourself
Our 3D Machine Vision Systems are showcased at many of the most popular industry tradeshows and events in the United States.
Visit us to learn about the possibilities for your application at our next show.
Fabtech logo
FABTECH
November 11 – 14, 2019
McCormick Place
Chicago, Illinois
BOOTH NUMBER: A1407
www.fabtechexpo.com
Web Content Viewer
Actions
