Web Content Viewer
Actions
THE PRINTER
YOU WON'T HATE.
THE PRINTER
YOU WON'T HATE
AVAILABLE EARLY 2019
WG7200 SERIES MULTIFUNCTION PRINTER
Inspired and informed by professionals like you, who are trying to fit 12 hours of productivity into an 8-hour work day, the Canon WG7200 Series is there day and night, by your side to cover your back. Businesses can count on the WG7200 Series for exceptional performance, every day, on every job.
Self Serviceable Design
With only one replaceable part - the ADF roller kit, the WG7200 Series have superior maintenance and ease of use. Even the ink cartridges and maintenance cartridge are easy to access using the front panel.
Print & Scan Direct with USB
Easily print and scan directly to a USB flash drive without a computer, by using the convenient USB 2.0 port next to the LCD touchscreen.
Wide Range of Media Support
The WG7200 Series supports a variety of media types such as envelopes, long paper, and even matte photo paper. The printer can support weights up to 256 g/m2 and paper sizes up to 330 × 711 mm.
Jam Defying Design
Designed specifically with a straight paper path to help reduce and prevent paper jams, the WG7200 Series can confidently handle large volumes worry free.
High Density Black Ink
Utilizing a high-density black ink to print vivid and sharp office documents, the text on reports, emails, spreadsheets, will always be are crisp and easy to read.
High Speed Printing
With fast 80 pages per minute (ppm) in monochrome printing, print large volume jobs quickly.
Connectivity
Easily print from your Ethernet or favorite devices by connecting NFC, Wi-Fi®, and AirPrint®.
High Speed Printing
Connectivity
OPTIMIZED PRINTING SOLUTIONS FOR SMALL BUSINESSES
USABILITY
Easy Setup - The user-friendly, 5-inch color LCD touchscreen makes setting up the printer a breeze, even for first-timers, by displaying the instructions on-screen.
Simple, Intuitive Touchscreen - Easily navigate through all printer operations within one simple, intuitive touchscreen.
Wide Range of Media Support - The WG7200 Series supports a variety of media types such as envelopes, long paper, and even matte photo paper. The printer can support various paper weights and sizes up to 13" x 19".
Print & Scan Direct with USB1 - Easily print and scan without a computer, by using a USB flash drive with the convenient USB 2.0 port next to the LCD touchscreen.
Self Serviceable Design - With only one replaceable part - the ADF roller kit, the WG7200 Series have simple maintenance for ease of use. Even the ink cartridges and maintenance cartridge are easy to access using the front panel.
Automatic Paper Size Sensor - Built-in sensors detect the size of the paper you load into each cassette and adjusts the printers settings automatically.
PERFORMANCE
Jam Defying Design2 - Designed specifically with a straight paper path to help reduce and prevent paper jams, the WG7200 Series can confidently handle large volumes worry free.
Newly Designed Printhead for Stable Printing - The newly developed print head spans the full width of all supported paper sizes - meaning the print head doesn't move across the page, achieving high-speed, accurate printing.
Anti-Curl Technology - With new ink formulations, the amount of colorant in the ink is increased, with water content reduced and an anti-curling solvent added.
Dual Nozzle Check Mechanism - Featuring optical and in-nozzle sensors, the WG7200 Series can monitor ink ejection in real time and make adjustments as necessary for the best results.
High Density Black Ink - Utilizing a high-density black ink to print vivid and sharp office documents, the text on reports, emails, spreadsheets, will always be crisp and easy to read.
Newly Designed Ink Formulation for Better Performance - With a new formulation and low surface tension, the WG7200 Series inks are able to absorb into the paper more quickly than traditional ink methods.
PRODUCTIVITY
High Speed Printing3 - With up to 80 pages per minute (PPM) in color or black-and-white printing, print large volume jobs quickly.
Fast First Print Out3 - High-speed fast first print out time (FPOT) of 6.5 seconds from ready mode.
Single-Pass Duplexing4 - Simultaneously scans both sides of 2-sided documents in a single pass at 65 ipm.
Digitize Documents Fast - Rapidly digitize large volumes of documents for efficient file retention and data storage.
High Paper Capacity - Reduce the frequency and time required to replenish paper during large print jobs, due to a maximum paper capacity of up to 2,250 sheets.
FIND THE RIGHT SOLUTION FOR YOUR SMALL BUSINESS
The needs of your small business are unique, and the Canon WG7200 Series has solutions to fit every need.
FEATURES
Models shown with optional
CF10 Paper Cassette Feeding Unit.
WG7250Z WG7250F WG7250 WG7240
Print Speed (PPM)3 50 / 80 50 / 80 50 / 80 40 / 70
Fast First Print Out Time (FPOT)3 6.5 Seconds 6.5 Seconds 6.5 Seconds 6.5 Seconds
Functions Print, Copy, Scan, ADF, Fax Print, Copy, Scan, ADF, Fax Print, Copy, Scan, ADF Print, Copy, Scan, ADF
Jam Defying Design2 A check mark A check mark A check mark A check mark
5.0" LCD Touchscreen A check mark A check mark A check mark A check mark
High-Density Black & Highlighter Resistant Ink A check mark A check mark A check mark A check mark
Standard / XL / XXL Cartridges A check mark A check mark A check mark A check mark
Single-Pass Duplex Scanning A check mark A check mark A check mark A check mark
Scanning Speed (IPM)4 40 / 65 40 / 65 40 / 65 40 / 65
Ethernet A check mark A check mark A check mark A check mark
Wi-Fi® / Wireless5 A check mark A check mark A check mark
AirPrint®6 / Mopria® Compatible7 A check mark A check mark A check mark
Fax Capable A check mark A check mark
NFC8 A check mark
Shift Sorter A check mark
Standard Paper Cassettes (2) 1,150 Sheets Total (550 Sheets / Per Cassette (x2 Cassettes) +50 Sheet Multi-Purpose Tray)
OPTIONAL
+2 Additional Paper Cassettes (OPTIONAL) 2,250 Sheets total (550 Sheets / Per Cassette (x4 Cassettes) +50 Sheet Multi-Purpose Tray)
Disclaimer
SPECIFICATIONS ARE SUBJECT TO CHANGE WITHOUT NOTICE. ALL VIEWSCREEN AND OUTPUT IMAGES ARE SIMULATED.
  1. Supported file formats include: JPEG, TIFF and PDF.
  2. "Jam Defying Design" refers to the WG7200 Series straight paper path designed to help reduce and prevent paper jams.
  3. Print Speed is based on ISO/IEC 24734 including Canon original method. Measured in default mode (General Office Mode: 600dpi) / fast mode (Office Document Mode: 300dpi). Print speed varies depending on system configuration, interface, software, content of document, print mode, media type, weight and used cassette, etc. Print Speed (FPOT) is based on ISO/IEC17629. Print speed varies depending on system configuration, interface, software, content of document, print mode, media type, weight and used cassette etc.
  4. Average copy time from ADF. Set the original on ADF and measure time from pushing the scanning button to output the copied paper. Based on ISO/IEC 17991 scESAT30secA. Scanning Speed (SEND), measured in Canon original method is based on ISO/IEC 17911, scEFTP30secF. ADF scan speeds/Scanning speed (SEND) vary depending on system configuration, interface, software, etc.
  5. Wireless printing and scanning requires a working network with wireless 802.11b/g/n capability, operating at 2.4GHz. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
  6. AirPrint functionality requires a compatible iPad, iPhone, or iPod Touch device running iOS 7.0 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to Mac running MacOS X 10.9 or later supports AirPrint via USB connection.
  7. Requires Android mobile device with Android 4.4 operating system or later with the Mopria Print Service pre-loaded with that device and the compatible PIXMA printer on the same wireless network. The Mopria experience is also available on Android 4.4 mobile devices with a download of the Mopria Print Service from Google Play.
  8. Requires an Android mobile device with NFC hardware running Android 4.4 or later, and the Canon Print Business app, available for free at Google Play. Canon Print Business app must be open to use tap and print functionality. Requires an Internet connection and the Canon PRINT Business app, available for free on the App Store and at Google Play. Compatible with iPad and iPhone devices running iOS 10.0 or later, and Android mobile devices running Android 4.4 or later. For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app. Certain exceptions and restrictions may apply.
